Park Pilot OBDEleven
Alienatrix
63
12
Apologies in advance if the answer is somewhere, but struggling to find it at the moment.
I have a 67 plate Leon FR Estate. I have only the Rear Parking sensors and want to activate the Radar screen thingy...
I have just received my OBD Eleven through the post today. What do i need to do to activate it?
Many Thanks..
Deleted member 103408
Alienatrix
63
12
Unfortunately the above doesn't work as i don't have Module 72 on OBDeleven.
Tried looking for it to add it on but nothing's there.
Any more ideas?
Can you give us a list of Modules that you have on your car, eg what comes up when you run a scan.
Alienatrix
63
12
16 Modules available all together.
The last one is Parking Assistance ( Module 76 )
However nothing in there that i could change or enable to get Park Pilot Screen on.
Unfortunately Module 72 just isn't coming up as an option to add.
ok well I dont have the car so very difficult to answer.
However I went to the Spanish site where they have some factory backups and found this
Control Unit: 76 Parking Assistance
System description: PDC 8 Kanal
Software number: 5QA919294B
Software version: 0044
Hardware number: 5QA919294
Hardware Version: H07
Serial number: 00030841861715905936
ODX Name: EV_EPHVA18AU3700000
ODX Version: 009035
Backup name: 76 Parking Assistance-5QA919294B
Extended coding:
0471051001
Adaptations:
Speaker volume for rear park assist:
Stage 6
Speaker frequency for rear park assist:
Stage 4
Speaker volume for front park assist:
Stage 4
Speaker frequency for front park assist:
Stage 6
Audio reduction request:
On
Park assist activation tone:
On
Switch-off speed for parking assist:
15 km / h
Increment for convertible volume levels:
255
Convertible offset for volume level 1:
255
Acoustic warning for rear lid assistant:
not active
Wheel circ .:
1980 mm
Distance to curb:
15 cm
Activating and deactivating all development messages:
Dev_Id_Low_Nibble:
Not activated
Dev_Id_High_Nibble:
Not activated
Production mode:
Deactivating
Deactivate production mode:
Deactivating
Customer-oriented off-road trip:
Not activated
ARA angle control parameter:
Vehicle overhang:
1.076 m
Max. Controllable corners:
0.180 1 / m
Max. selectable corners:
1,308 1 / m
Automatic activation:
activated
Mileage: 159 km
Date: 2017-07-09 18:00
and on the my18 it shows
Backup
Control Unit: 76 Assisted parking
System description: PARKHILFE 4K
Software number: 5Q0919283F
Software version: 0054
Hardware number: 5Q0919283
Hardware Version: H10
Serial number: 39231528704490
ODX Name: EV_EPHVA14AU3700000
ODX Version: 002024
Backup name: Monday24
Extended coding:
0000050001
Adaptations:
Volume of loudspeakers for parking after:
stage 4
Frequency of loudspeakers for assisted parking after:
stage 4
Audio descent requirement:
on
Activation tone p. assisted parking:
on
Production mode:
deactivate
deactivate
Deactivation speed p. Parking aid:
10 km / h
Mileage: 20284 km
Date: 2016-10-24 17:09
both imply you should be able to make some changes to the adaptions.
Can you do a backup of the module and post it please
and what did you see. error or nothi g
Sent from my SM-G920F using Tapatalk
Alienatrix
63
12
My concern is that i could not adjust everything as the setting above.
I am literally a newbie to the OBDeleven app.
I have tried to understand how to make certain changes but i am really struggling, which why i was hopping someone could give me a step by step change list of changes they made.
That way, i know where to go and what to change.
Sorry.
