PAS
Sep 5, 2024
what is in the error log?
That's the thing, no error whilst idling and no power steering.. light will come on dash when wheels rotate.
When reading settings at idle with no PAS, terminal 15 is below 10 volts, i thought that terminal voltage should be ignition volts? Terminal 30 is 14+volts
cairus
1,577
552
then I would look at the contact block at the ignition lock. It often breaks
