No thanks, some breather systems create purging systems throughout the engine, if you remove them out of the system, then no vacuum or positive pressure when the engine is designed for it.
You're not removing the breather system. You're stopping it from depositing all of its sh*te back into your oil and getting rid of the factory spec chocolate hoses in one foul swoop.
If you have a valve that's designed to work under certain conditions and you remove it then you are altering the breather system, this may or may not mean you are no longer have negative or positive pressure where the engine wants it.
I don't have a problem with catch cans but I do have a problem with removing the pcv valve.
