My other half got her 03 Cupra last week, I've just removed the EGR cooler and I've modified the standard EGR as per a few guides I've seen on some forums so I've retained the shudder valve. It was all rather gunked up!!!
While I was at it I cleaned out the inlet manifold and fitted a new gasket.
Now I've not driven the car much but before I don't recall it sounding like it has a boost leak. If you put your foot down between 2500-3000rpm then it sounds like someones momentarily putting the heater blowers on low!
So I'm presuming boost leak? Anywhere I should look? I did have problems getting the clip back on the turbo inlet pipe (being down the side of the engine) but I was confident I got it on in the end.
Also maybe unrelated but it's had poor MPG since we got it, around 40mpg "normal" driving and 45mpg driving steady.
