Does anybody know if you can adjust the break and accelerator pedals so that they are more at the same height?
I was driving a new style Honda Civic (i dont like it!!) and i did notice that the pedals were much more about the same height which made heel-toe breaking/gear changes much better when going into corners.
I had tried this many times in my FR but the pedal difference is too much to do it comfortably/safely.
Stuart
For those not familiar with heel-toe, its an advanced driving technique whereby as you break prior to a corner, immediately before you turn the wheel, you change down a gear but pre-rev the engine to limit the transmission shock.
With heel toe, you keep you toes on the brake, pivot your heel over to the accelerator and 'blip' it as you let the clutch out.
This means, if you have been doing 4k rpm in 4th, break down to 1100rpm and pop it into second to go round and power out the corner, the 'blip' of power raises the rev's up roughlt to around the area they will be when you let the clutch out.
If you had been doing 4k rpm in 4th, then break to 1100rpm, then move into 2nd, as you let the clutch up there will be a physical jolt which could destabilise the car.
The only other way around this is to let the clutch out slowly and allow the transmission and engine speed to equalise slowly. Problem here is your possibly coasting round the corner
The way alot of people do it is you brake well in advance of the corner so you have time to take your foot of the brake and pre-rev the engine as you do the gear change before the corner - this isnt heel toe but is a good idea any time you are changing down.
http://www.youtube.com/watch?v=Fj-YlmRYL2o&feature=related
Some vids on youtube show it, some YT vids show it with double-de-clutching which isn't normally needed but helps get the gear box at the right speed too and the syncros ready for the shift - i cant do double clutching!!
Stuart
