dsj20v
147
hampshire
Hi all after some definite answers from all u running biggish turbo set ups, I'm currently building up my 1.8t 'aum' with ie rods/garrett gt28rs/550genesis injectors/ small manifold/ lightly played with head with supertech valves and so on BUT what I want to know as I'm budgeting for a diff, Will a oem cambelt kit b ok as heard lots of talk about manual tensioners etc, Will new oem headbolts b ok as opposed to arp ones, whats the best ,metal impeller/plastic impeller Waterpump again as hear conflicting reports, I'd like Bill to map it but I've emailed him but no reply so I guess he's mega busy, so I've now contacted another very good company but still awaiting reply, But I'd like a definitive answer so I can order bits and move on with build, many thanks
not seen your email.. :confused:
std head bolts fine
metal impellor pumps wont fail on their pump impellors, but every one I have seen has a weep thru the main shaft seal.. i am back on plastic oe pump on mine... will see how it fares
cambelt fine.. manual tensioner is a preference.. I run one now, but ran std before.. no issues either way.
I went with ARP Head stud kit, ARP rod bolt kit. I would get metal impeller, i have the IE Cambelt kit which i did 5000km ago but i changed that to OEM again because it had become very soft.
