dfc101
Hi all,
I'm having what seems to be a fairly common problem among some VAG lines with a 2003 1.2 Mk4 Petrol Ibiza Sx:
During acceleration (across all gears) there is a sudden power loss which is resolved by taking foot off the accelerator and then reapplying (it can also be resolved by left foot braking with right foot still on accelerator). This can be intermittent and sporadic which suggests an electrical fault. It fired up an EPC code on to the dash. From searching around I found the most likely reason for this was a fault brake light switch. I plugged in and read the codes and it backed this up – saying that the brake light switch was failing.
I acquired a genuine part from a Seat dealer and replaced the brake light switch. The car ran fine for a few miles before suffering the same problem again. I did however notice that the lower brake lights (ie not the boot lid centre light – this operated correctly) were always on when the lights were turned on.
I haven't got the opportunity to read codes again for about a week as I borrowed the kit from a friend. So until then, does anyone have any ideas what could be causing the fault? Would replacing the brake light bulbs be a good idea given its cheap to do? Am I focusing too strongly on the brakes, could it be something else?
Notes:
The cars recently been serviced (minus bulb replacement), had a clutch replacement, and has had a new MAP sensor fitted a couple of weeks before this fault occurred. Other than that it's been a smooth runner from purchase. It's only got 50k on the clock!
I've noticed moisture buildup in the rear lights recently and am wondering if this could have caused a problem at the bulb socket?
Cant think of any other info I'm missing!
Thanks for any input,
Dave
Notes:
Dave
