Poll-fan fuse on battery melted/replaced or not?
My fan fuse on battery has melted/been replaced
  • yes
    Votes: 108 70.6%
  • no
    Votes: 45 29.4%
  • Total voters
    153
matt27
thanks for your help
the oxford dealer gave me the part number 1J0 937 617C, the Kent dealer's wanted to know the battery amp power first - gave both of them my chassis number.
I have no idea what the amp power is? I think I need the
Fuse box:
1J0 937 555 cover for fuse holder
for models with battery: 44AH
I bought and fitted a Halfords battery last year:
Halfords Calcium Battery HCB063
Startup Power: 440 Amps
AH Value: 44
Reserve Capacity: 80
Bench Charge: 4.4 Amps
Weight (kg): 11.68
Sorry and many thanks again!
matt27
update: AC and fans still auto starting and not turning off, so definitely not the battery fuse box to blame.
Also with the new fuse box part, it takes a lot of strength to push in the fuse and pry it out, so this seems to be normal and does not indicate a fault. Time to start saving for another car, am not going to bother taking it to a garage for repair, I suspect a repair will be very pricey if they can find out what's wrong with it!
manzfield
104
st austell
look at this checked it earlier after reading this....
Sent from my GT-I9000 using Tapatalk
Cammy
190
My fans dont work atall... i was thinking its the fan switch?
My cars done 56k miles, but.. the fuse board on top looks perfect??
Cammy
190
One had slight melting (3rd across - the one nearest passanger wing fuse) is that the fan one?? Is it worth getting a spare one from the scrappy??
yellonvi-R
4,331
birmingham
The melted fuse holder has probly ruined the connection between the fuse and the prongs it slots into! You can get away without changing the whole thing but you will need to disconect the wires that go to that fuse a rewire them into a seperate fuse holder...like what you see on a stereo amp power lead ;) that is the fan fuse though.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
My fans are melting the new fusebox again slightly,
people say its resistors in the fan but are resistors located seprately?
