Dave_C
I recently replaced my console/wishbone bushes on the front of my ibiza (the ones that always go) and used the uprated cupra bushes. This, as you'll probably know, means removing the front subframe and fitting the new bushes, then faffing on for ages getting things to fit back where they used to (harder then it sounds!).
Since I replaced the bushes and completed the job my steering wheel has been off centre by quite a way. I think the problem will be one of two things;
- the steering rack was not aligned and 'centered' when I refitted it; simple fix being to the remove it, re-centre the wheel and bolt it back on.
- because the subframe and other 'suspension' components were taken off then replaced the car needs proper 4-wheel alignment to ensure eveything is straight and safe again.
Any ideas?
Any ideas?
