Problem coding RVC on Leon using VCDS
KoNG
539
126
London
it looking like your unit is faulty. just to clarify one more time you go to gateway installation list and then Select unit 10 tick the box and click save. if you go back to list is this unit still marked?
Youngers
27
Hi kong yes I register the park assist module in the can gateway and save. Then when I read fault memory on the gateway its showing the fault I previously pasted for you and I am unable to clear it until I remove the park assist module again. Also with the module registered I am unable to connect to and showing no communication error when attempting to. Yes I believe the module is also faulty. Would it be ok if I was to be one from another vehicle just to test it?
Thanks again
Chris
