Pulling to the left
ShiftySid
87
Hi guys, my Cupra has always pulled slightly to the left right from new. However a couple of months ago I hit a massive pot hole at about 50mph. The whole car juddered all the way home. I took it in for wheel balancing and tracking and they told me the alloy was bent too.
Got all those fixed but it still pulls to the left, only a lot more than it ever has. I've had the tracking done three times at three different places. It seems OK for the first few miles then just seems to go again.
I took the car in for damage checks last week and was told the bushes, steering, tracking rods and suspension were all fine.
The other thing I've noticed recently is the handling doesn't feel quite right. It feels a little wallowy and definitely not as sharp as it was before. Almost like driving on a greasy road surface - a bit squirmy.
Has anyone got any suggestions what the problem might be as I don't know where to go from here. All my tyres are virtually new and at the correct pressure by the way.
When driving straight I have to angle the wheel at the ten to four position just to keep in a straight line. It's so bad I actually hate driving it at the moment.
Cheers.
Sent from my HTC One using Tapatalk
DEAN0
Old Git
Feb 1, 2006
5,303
312
Preston - UK
I would take the car in for a full 4 wheel alignment check.
Yes I know the back is not adjustable but the geometry of the back also affects the front.
As a minimum the 4 wheel alignment should check :
Toe - front and rear
Camber - front and rear
Caster - front
Ride height - compare left to right ( possible snapped spring etc )
Slip angle - rear axle ( is the rear axle's normal direction in line with the chassis )
Slip angle - front axle ( is the front axle tracking line in line with the chassis )
Steering wheel position - ( is it straight ahead when the car is going straight )
Max lock angle - is the steering lock the same on both sides ( ie, is the rack in the middle when going straight )
ShiftySid
87
Thanks for the reply.
The last time I had the tracking and balancing done (June) they told me the rear wheels were quite a way out but as you stated 'cannot be adjusted'.
So, on the assumption that is what I should look at in the first instance, what is the solution if it is non-adjustable? A new car?
DEAN0
Old Git
Feb 1, 2006
5,303
312
Preston - UK
Although it's non adjustable in the "turn a bolt" sense - a professional alignment place can do the adjustments.
You can get "camber/toe wedges" that go behind the stub axle and correct the figures.
Not as cheap or simple to do as the front but still do-able.
ShiftySid
87
Is it possible the back being out could cause pulling to the left? I've heard mixed opinions on this. Thanks.
DEAN0
Old Git
Feb 1, 2006
5,303
312
Preston - UK
Yes - if the slip angle of the rear axle is off it will make the car crab slightly - this will need a steering correction for the car to go straight
ShiftySid
87
Hmm sounds like this may be the problem then particularly if all the wheels and rods etc check out OK. I've found a decent looking place online so I'll get my car booked in and let you know how that goes. Cheers for your advice.
ShiftySid
87
Right, taken the car in for a four-wheel alignment. First they told me that the rear wheels could be aligned and they'd adjust it for me, but when I collected it a different guy told me the rear cannot be adjusted on this model so they couldn't do it. Hmm.
Anyway, here are the before and after readings for the front - suffice to stay it still pulls to the left just as much as it did before I handed over my £30!
Front caster:
left 4.09 before, 4.09 after
right 4.03 before, 4.03 after
Front camber:
left -1.29 before, -1.40 after (is this actually worse? I don't understand what the numbers mean)
right -0.35 before, -0.31 after
Front toe:
left -0.11 before, 0.05 after
right 0.05 before, 0.07 after
total 0.16 before, 0.11 after
Rear camber
left -2.23 before, -2.25 after
right -1.29 before, -1.30 after
Rear toe
left 0.32 before, 0.31 after
right 0.14 before, 0.14 after
total 0.46 before, 0.45 after
The guy said he road-tested it (and he did as it had an extra five miles on the clock when I collected it) and he assured me it was dead on.
Driving home, I could still feel it pulling quite hard to the left. He gave me the usual spiel that it was probably the camber of the road so to test that theory, I drove on the wrong side of the road when I got near to my house as there is a long stretch of quiet road so it was safe to do so. I expected if it was camber of the road I would then be pulled to the right. Not so, it still pulled hard to the left.
So if anyone understands what these readings mean, I'd be grateful for any further advice.
PS: They had the car all day and checked the bushes, springs, track rods and ball joints and all were absolutely fine.
DEAN0
Old Git
Feb 1, 2006
5,303
312
Preston - UK
The answer to your pulling is there - but it has not been adjusted.
Your front camber is different side to side.
Your front RIGHT wheel is leaning in at the top by 0.35 (0.31) degrees
Your front LEFT wheel is leaning in at the top by 1.29 ( 1.40 ) degrees
This means that the front RIGHT wheel has a larger footprint in a straight line.
I would question how the numbers have changed after adjustment because it is non adjustable as standard
And based on that I would also question any other readings they have taken for accuracy.
ShiftySid
87
Thanks for that.
Just phoned the dealer who said the front camber isn't adjustable so it must be suspension or steering and to 'bring it in' - where I expect they'd charge me another £60 and still not fix it which is why I went to a specialist wheel alignment place.
Phoned back the company who did the alignment and they confirmed front camber wasn't adjustable but altering 'toe' can have an affect on camber (apparently). They confirmed all the bushes, suspension, ball joints etc checked out ok (as did another local garage a couple of weeks ago).
I don't know what to do now, you're saying it's the camber reading above and they're saying it's not out by enough to make much of a difference and that it can't be adjusted anyway.
Time to trade for a Golf GTi or Audi A3 me thinks...!
DEAN0
Old Git
Feb 1, 2006
5,303
312
Preston - UK
Not sure how they work that one out.
The camber is decided by top mount position, bottom ball joint position and ride height.
The top mount is fixed and can not be altered.
The lower ball joint is fixed BUT if the mounting holes are slotted the camber can be changed.
The ride height will not have changed during the alignment.
I would do a quick measurement on each side of the car to see if it sitting level ( the LOW side would have slightly more camber if there is a difference )
ShiftySid
87
The ride height is the same all round. The measurements were also on the alignment print out. Should I take it back, take it somewhere else or just give up?
Nov 23, 2010
873
Dunfermline, Fife
ShiftySid
My son has a 3 week old cupra and pulled to the left from 4 miles on the clock. Setting tyre to correct pressure made little or no difference. When i had a boc it also did this.
I think they just DO, and there is not a lot can be done.
Something you just gotta live with :blink:
ShiftySid
87
Thought as much. My previous car (Astra SRi) did exactly the same. Had that for five years and this for three. 8 years compensating the steering is very tiresome. Any cars out there that don't pull left?
Nov 23, 2010
873
Dunfermline, Fife
My new focus surprised me home straight it feels on most roads, as long as your not giving it the beans.. Then u need 3 hands...
ShiftySid
87
I want an A3 or Golf next. Being VW I wonder if they will both suffer the same pulling?
Nov 23, 2010
873
Dunfermline, Fife
Traded a octavie vrs blackline in on this ford, that too was fine steering wise.
Re reading your original post, it sounds like something is bent and may not be cured by alignment.
Good luck sorting this out mate.
ShiftySid
87
Thanks. I've wondered the same but I've spent loads on alignments at different garages and it's always done it so for the sake of another year I will put up with it and trade it in. Will be someone else's problem then.
Which model Focus did you go for? ST? :)
Nov 23, 2010
873
Dunfermline, Fife
Yeah bought a new st-2 in black. Couldn't bring myself to order the Tangerine Scream yellow!
Quick car but miss the auto from the boc and the vrs... Next time!
Son just bought a new red cupra so hopefully can borrow that sometime :)
DEAN0
Old Git
Feb 1, 2006
5,303
312
Preston - UK
I don't have any pulling with my Ibiza 2.0TDi
Having said that - I had the alignment checked soon after i got it ( Just one of those things i do when a car runs well so i have reference numbers.)
Front caster:
left 4.05
right 4.04
Front camber:
left -0.99
right -1.01
Front toe:
left -0.03
right -0.03
total -0.06
Rear camber
left -1.76
right -1.81
Rear toe
left 0.32
right 0.34
total 0.66
