gchuggins
Hi all, I have a 2006 SEAT Ibiza 1.4 Sport. Its pretty stock standard with no modifications at all. My car does need new brake all round and I was really looking to do a rear drum to disc brake conversion and I will be very interested to know if someone has done it before or knows how to do it. If someone has some input on the subject, any response will be greatly appreciated.
Thanks in advance,
Gareth
no idea if anyone's done it or if indeed its possible but the back brake discs are small and the vast majority of the braking is done by the front discs so gains would be minimal but costs would be high.
Agreed. Some would also argue that drums are easier to maintain, the normal rear disc calipers have been known to give trouble if they're not looked after. And even when they're working they need a dedicated windback tool to replace the pads. Drums might seem 'old school', but they're very reliable and easy to work on.
You'll get much bigger gains from a front disc upgrade.
One thing about rear drum brakes is, in my past experience, and the present experience of my daughter with Ibiza 1.4 SC, is rear drum brakes are fine until either you or the garage ignore them, so they only ever get looked at after they fail - and they will. First failure is typically the old problem that they seize on after the car has been left unused for a week or so in wet conditions. In my daughter's case it needed the AA with a large hammer, her previous Ibiza 1.4 also did that. Eventually when she went abroad for a month, I took the drums off and found the shoe linings had fractured, new set of shoes cost a lot more than a set of rear pads. Now I know that these cars don't need extra rear braking, but, my wife has a Polo 9N 1.4 SE - with rear discs, and its very easy to service them every year and keep them working. I'm always worried with rear drums, in as much that you might have a big problem retracting the shoes to get the drums off, with the added bonus with some cars that the rear bearing gets wrecked when forcing the drum off. I'll still be looking for rear discs brakes when my wife's car gets replaced - but only for ease of servicing.
Thanks a lot guys your advice has been really helpful, I still need to service the brakes but I'll keep it as drums
