hi is it a 3 door? or 5 door?
this is for a 3 door, if its a 5 door you do need adaptors and they are removed the same as the front!
the rear panel is not hard to remove just take your time! i got some new pop clips after as a few will usualy break.
you nee to remove the rear seats completly, to do this is very easy the seat base just pull forward and their is two peice of metal that just pop out.
next remove the back! drop them and at the pivet you will see two catches you will need a flat screw driver just move the slide catch back on side closest the door card and pull the seat up, in the middle you will find it has an insert so you need to pull toward the door card and it will be free.
door cards! start at the bottom and on the rear their are two round fixings you need to undo these by just turning with you hand till undone, when all the clips in the door card are undone you will find that you need to push the doorcard up towards the roof as their is three clips that are slid in along the window!
speakers are riveted in but you wont need spacers like on the front doors, but i do recall their only being 3 rivets and i needed to drillnew hole for the other screws
the trim along the front door just clips in just use a flat screwdriver and it come out easy, i hide 2 large rcas plus power for amp and remote amp on all in the gap just feed behind the setabelt and your in behind the doorcard which you can then feed along and if you want come out in the boot
hope this helps
