Hey All.
Not been around much since the birth of our girl but now she is out and about in her recaro baby seat, I have found some problems with the rear windows.
I have an MY07 Cupra and the driver side rear window seems to activate the anti squeeze feature about an inch from the top, causing the window to drop down again.
If you do this on the door switch as a one touch operation, it goes up, gets to within an inch of closing, then rolls back down.
If you hold the switch as if it was a manual close, it still goes up to within an inch but simply stops.
The best part is that after a few times the switch stops working and you then have to turn the engine off and on again to reset something.
Anyone had this type of problem before? I did search the Mk2 section for "windows electric rear" and saw nothing that I thought was relevant.
I will get it into the dealers to get sorted, however it would have been nice to get some background or experience of other owners with this problem.
I checked the runners where I could for any debris and could not find anything at all.
Any input is appreciated.
