Deleted member 123864
Heya all,
Is there any way to lift up or remove the base of the rear seat? I've a dog that got sick in the back seat earlier and some of the puke has gone down where the seat belt receptacles are. Impossible to clean up from above
These anchors, that get called grommets are "single use only", when you "rip up" the base, the anchor gets destroyed, they might look a bit expensive but from memory they are dirt cheap from any VW/SEAT/Audi/Skoda dealership - they all use the same fixing for the rear seats it seems.
So quite a bit of force and brute ignorance is needed to lift the seat base up out of these grommets - at each "front" corner one at a time.
