Rear sitting lower than front after installing lowering springs
Apr 30, 2021
35
Found a super deal on a H&R lowering sport kit, springs and struts, hoping to get a slightly better ride than my old coilovers.
Installed everything, measured the gaps and it stayed at the same height in every corner, nice.
After I went for a test drive, I checked again and the rear is now sitting 10mm lower than the front and the rear right side is even lower, around 6mm than the left.
How is this possible ? I had the care to align both springs to face the same way as I've read somewhere that could affect the height but in this case it didn't matter.
And yes the kit is correct for the axle weight.
Also as feedback for whoever reads this, this kit called comfort kit rides as stiff as my coilovers, in the highway I can still feel every imperfection every bump, there's a minimal improvement.
The only remedy for this car is thicker tires and original suspension, no other way around I give up.
