Jan 8, 2007
2,958
Wiltshire
After removing my rear wiper yesterday I've filled the hole with a 25mm plastic grommet from Halfords which seems to be the most popular choice but I notice these are still quite soft and very easy to push through.
Has anyone on here used anything firmer to plug the hole?
I found http://uk-mkivs.net/forums/t/200361.aspx which suggests http://www.venommotorsport.com/prod...0&manufacturer=Speedtech&category=Bodystyling but just wondering if anyone has done this any other way? I may try bonding it to the glass to see if that helps.
I just have a rebber grommit from local parts factor.
guess they're all easy to push through, but here's a tip
don't poke at it ;)
Got one in mine....It's actually a bung shaped piece of glass that fits perfect.....bonded to inside of glass..
Daz
Or if you go to Venom Motorsport they do a glass replacement version. Think it is £25 though
Sorry my bad, just saw that you pisted the link asking if anyone is running it. I will shut it now :doh:
Ours are just rubber grommets.
The only time i've had any bother with mine was when a mate poked it through, it's now superglued in place.;)
