Remove rev limiter
Deleted member 103408
No, this feature is across the VW Range I am afraid.
I am sure if you have professional ECU Tuning tools you could but not the sort of thing you can do with normal VCDS type Tools as far as I am aware.
i will give that a try on the DSG Box, but I have to say I go to lots of track meets where you have to do sound checks and they all accept you cant go above 4k
Damo H
4,707
2,816
Car Length In Front
I tried disabling the traction control, well as much as the Cupra lets you, and no can’t rev above 4k
I just did that test myself, my 2014 DSG and I tried with traction control on and off in both Park and Neuteral and in both cases cant go over the 4K.
cuprawill290
51
13
Northumberland
maybe my mistake but in manual you can rev over 4k with traction control off in neutral but clutch needs to be depressed, only goes to 3.8k with traction control on.
Don't think its a mistake its just another feature where there is a difference between different models (in this case DSG Vs Manual)
Hag
399
193
Turning esp off should give you more revs at idle, it’s the same with all VAG cars
