I wish to remove the air con from my fr tdi. I dont plan on selling the car so its another stage of modding im prepared to do after fitting my decat, partial smoothing of the airbox (to finish that) and the diy shortshifter.
Ive done it before on previous cars and only end up leaving the matrix for the A/C in the car. Apart from removing the componentry from under the bonnet, fitting a non A/C 1.9tdi aux belt what else would i need to do?? I know obviously the button on the climate will still ''work'' though i was wondering if this could be deactivated via vagcom??
Im guessing that its a dash out job to remove the AC matrix in the dash and that also the cold air that the car produces without AC is like most cars in that its a fan with an outside air feed typically under or near the scuttle panel?
tia
tia
