Removing front fog lights
Equalizer
103
Poland
Hello
I have a little problem. Can you tell me how to remove front fog lights in Leon CupraR 1M? I want to polish glass that covers lenses, because after ten years it became very unclear.
I know, that I must remove fog light grills and unscrew the two screws holding the lights, but I've encountered a small problem. When I'm trying to unscrew them, the screws are turning all the time, but not coming out from the plastic body :/
Do you know if there are some retaining nuts, that holds the screws from the other side?
Thanks in advance
Equalizer.
Jun 16, 2013
54
Uk
Had same problem when i got new fog lights from euro car parts. Try to soak with wd40 or something and yes from what i remember there is bolts on the back.
And very awkward to get too.
bendyb633
77
Lyneham, Wiltshire
Hi mate, it sounds like the threads have stripped on either the retaining nuts or the bolts. I'd suggest that you grip the fog light and pull it as you turn the bolts. You may need to use quite a bit of force when pulling. Hope this helps. Failing this, you may need to drill the heads off the bolts, remove the fog lights and use mole grips to remove the bolt shank. If your anywhere near Swindon and want a hand, drop me a line
Equalizer
103
Poland
Thanks for advices! I will try to get them out :)
Also- thanks bendyb633, that you want to help, but I live a little bit far from you. Only 1750km :) I'm from Poland (You know- kurwa country).
