this is the rear door card:
cheers
I imagine it being the same as the front passengers door card.
1. Remove cover of grab handle by putting your nails in between the joint and pull hard
2. Can't really see properly from your photo but i imagine their is a cap on the window winder and there will be a torx or philips head screw behind that in order to remove the lever.
3. At the bottom of the door card, there will be 2 or 3 torx screws, remove these
4. Inside the grab handle, there will be two big philips head screws, remove these.
5. Pull the bottom of the door card towards you untill enough clips are unclipped to allow access to the door handle mechanism.
6. Follow the cable from right to left towards the back of the handle, you will see a hook which connects to the chrome handle, unhook this.
7. Keep pulling the door card towards you untill all the remaining clips are unclipped.
8. Start at one edge of the door and pull the door card upwards to release it from the seal.
Any questions just ask.
