replacing clutch on a 1.4
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
how much would it cost to replace the clutch plate on a 1.4 average price?
clutch is heavy and wd40 on the cable is no longer working and should looking at replacing, so how much would i be looking at?
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
3-4hrs for the clutch, £50 for a clutch kit.
Clutch cable? £40, about 45 mins fitting time too.
suprisingly easy to DIY on a 1.4 though. easily done in a weekend with a haynes.
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
not got the equipment to do anything major, plus my dad is recovering from surgery so cannot help with it
would be something i would need to get a garage to do for me, so by the sounds of it its probably half a days work at a garage then
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
shame really, since I did it on my own with a basic toolkit.
but yeah - half a days labour, probably (sadly) cost more than the car is worth, but is worth doing :)
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Is it really quite straight foward to do??? Because my clutch is on its way out but didnt think i'd be possible to DIY. I have changed my suspension myself, and same with the brakes and fluid and couple of other jobs. could you please point out to me some main/special tools that i'd defo need :D
Mig
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
You'll need a 10mm spline drive (like torx but more splines) and a clutch alignment tool
But really - it's jack car up, remove starter motor, undo clutch cable & shift linkage. remove driveshafts, undo gearbox mount, undo front engine mount (remembering to support the engine) undo bell housing bolts & catch the gearbox.
about 8 small bolts hold the clutch in, clean it all up (that's why it's stiff) and refit.
hardest bit is refitting the gearbox as it has a funny centre of gravity.
Also - takes more oil than haynes suggests!
ibiza_95
1.8T MK2 Conversion
had the clutch done last year at 60 pounds labour, had the gearbox done recently for the same, but had to leave my new narked clutch on cos he wanted an extra 60 to swap that when i had the box done
(had to keep the car on ramps an extra day for it to come in, thus loosing buisness)
He said the clutch was buggered but its been ok since the box has been changed so as long as it stays put for when i sell it i should be ok :)
Yumann
1,638
Glasgow
How heavy is the gearbox? Can one man lift it and also where do you put the support for the engine? Not under the sump obviously
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
awkward to lift, but just about do-able.
it's about 30kg dry I'd guess, but like I say - funny cog
ibiza_95
1.8T MK2 Conversion
you would be best lifting it on with a couple of mates, or having some wood maybe across the top of the engine bay which you can just hang the box from. it is a heavy thing to lift, and definitely not easy to manoevre into position and push on on your own. everything else tho should be alright...
Oh and i hear the drive shafts are a bitch to undo.
