Replacing rubber door seal
GS16LRHP
247
My drivers side rubber door seal is scuffed from shoes and the rubber has an area that's almost worn through to a hole.
How easy is it to replace the door seal and would I need any special tools?
Dopedpanda
"Old" Hardcore Ford Fan
Jun 15, 2013
172
Denmark
You need to remove all the trim around the lower a pillar, dash board trim against the seal, complete b pillar trim, and be real careful not to make a mark in the headliner when removing it.
Its about an hours work if you haven´t done it before.
GS16LRHP
247
I haven't had a chance to replace the seal. I took a good look and there seems to be a lot of work involved to remove the seal, most of the trim has to be removed. While I was researching I found the following:
Lower B Pillar removal:
http://workshop-manuals.com/seat/le.../lower_b-pillar_trim_removing_and_installing/
Side trim:
http://workshop-manuals.com/seat/le...emoving_and_installing_a-pillar_trim_?_05.00/
Upper B Pillar:
http://workshop-manuals.com/seat/le.../removing_and_installing_upper_b-pillar_trim/
Headline removal (not sure if this is required, but I posted a link for reference anyway):
http://workshop-manuals.com/seat/le...g_and_installing_moulded_headlining/removing/
