Replacing subwoofer
Major Tom
229
8
Been thinking of it for quite some time - ever since getting the car brand new I've been disappointed on the so-called subwoofer. Just a plastic bucket with a 5-inch (?) in it. Still don't wanna pay a lot, want to keep trunk space and easily be able to remove it.
Now looking for the Alpine SWE-815 active box. Thinking of just taking the speaker wires from the SEAT sub to the high level inputs of the Alpine amp. Also read somewhere that the Alpine has auto-power-on on the high level inputs so no need to take out the MIB-II head unit for remote lead.
Then will try with and without the SEAT sub.
Any suggestions? Where do I route the power cable from the battery, or should I connect it to the OEM fuse box? The power cable seems to be really thin. Thanks
:help:
KoNG
528
116
London
I recommend you to do first software update on your MIB unit as there is manor bug on subwoofer volume and this has been fixed with new update.
Fraser87
132
What is the mib unit and how do I find out which software I'm ruining at present?
Sent from my SM-G935F using Tapatalk
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
MIB is your head unit ( the bit you stare at and prod if you have the sat nav) software details are in there somewhere under system I think. Sorry can't be more specific, I'm not near the car atm
Major Tom
229
8
It seems to be a mishmash with versions on MIB-II HW and FW versions, but I think I have a pretty late version. It plays as good as it can being the cheap sh*t it is.
I've revised the idea above on the small Alpine box, will go for a bigger one.
Has anyone upgraded the stereo in a Leon MK3, any photos? Can you get RCA and remote from a MIB-II? How do you remove the MIB-II from the dashboard?
madvello
38
Estonia
Some information:
The speaker configuration varies depending on the
audio system and the target market.
Up to 4 speaker configurations are offered, with 4, 6, 8
or 10 speakers. The most comprehensive configuration
corresponds to the SEAT Sound System (10 speakers)
for the Navi System or Navi System Plus infotainment
systems.
The SEAT Sound System has the following
characteristics:
CENTRAL SPEAKER
Diameter: 97 mm.
Impedance: 4 ohms.
Frequency range: 150 kHz.
Attachment: 2 screws.
Connector: 2-pole.
WOOFERS IN FRONT AND REAR DOORS
Diameter: 152 mm.
Impedance: 4 ohms.
Frequency range: 60 Hz-3 kHz.
Attachment: 4 rivets.
Connector: 2-pole.
TWEETERS IN FRONT AND REAR DOORS
Diameter: 38 mm.
Impedance: 8 ohms.
Frequency range: (5-20) kHz.
Attachment: heat-welded at 3 points.
Connector: 2-pole.
BOOT SUBWOOFER
Volume: 10 L.
Impedance: 2 ohms.
Frequency range: 45-300 Hz.
Attachment: plate on spare wheel.
Connector: 2-pole.
Curtly
893
19
Essex
The front speakers are 8 inches (20cm).... I've measured them myself. The rears are 6.5 inch
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Our of curiosity...
I'm guessing the '6 speaker' 2 woofers (8") and 2 tweeters in front, and just 2 woofers (6.5") in rear doors. Headunit is basic one...4x15 watts?
8 speaker setup (Technology Pack or standard FR w/o Tech Pack) is 2 woofers (8") and 2 tweeters in front, and 2 woofers (6.5") back plus 2 tweeters. This needs at least the Media plus/Sat Nav. Power is 4x20 watts?
10 speaker setup, same as above but, rears are (8") woofers, + 1 centre (4") + 1 Sub.
Need Media Plus/Sat Nav. Power comes from amp in sub, and gives out 135 watts. 4x25w + 10w centre + 25 watt sub?
Raven
223
11
Our of curiosity...
No external amp in Seat Sound.
Sent using my fingers, above contents might (will) have traces of bad gramar
Raven
223
11
Wow the Heat Unit itself can output 6 channels @ 135watts total?
More likely 4x15 or something like that..
I think the speakers combined w is 135... nothing said about the output.
The 8x speaker system uses them same speakers as SEAT Sound all around.
Seat Sound is just added sub and center
SWANSWAY CUPRA Dealership
