Deleted member 108414
Hi all,
I have recently moved on to an Mk2 Leon FR from a Mk5 Golf. I miss the auto lights function and wondered if this can be retrofitted? If so, how hard is it to do and what parts do I need?
I have VCDS so coding is not a problem.
Thanks in advance
Thanks for the info. Do you know the part number for the sensor at all?
1P0 955 559 - sensor
4E0 955 609- gel foil
1C0 973 119B - flat contact housing
5P0 955 737- covering plate
1P0 955 433 - retaining spring
5P1 941 431CC 1MM - headlight switch
That's great. Thank you!
Sorry to resurrect an old thread, but I am looking to go this route and I have a question. If I was to buy the above parts, where will the light sensor plug into? I've been looking at the Chinese copies as well with the light sensor attached, and might just decide to try and modify one if using an OEM light sensor would require a lot of extra wiring or taking the dash apart.
