Yes, extensive threads on German & Spanish forum:
You can use auto google translate.
Reactions: Mark300zx
Thanks, can you spoil the ending and tell me if they were successful?? :D
This a retrofit i did not do, sorry.
But..yes, they were succesfull.
any way...you need vcp to flash correct dataset to the sensors.
Finished it this weekend. Easy coding, PITA hardware installation. VCP is not necessary since these radars come with the correct dataset.
By "classes" you mean? All parts were purchased from aliexpress as a "Golf Mk7 set". Only the wiring harness is custom made for our Leons 5F and the mirrors are from Arona.
Look for a shop named Aidu Auto and you will find everything you need there. Mirrors better be from a dealer. The price is reasonable.
Can you please put link here i cant find it?
Very interesting retrofit! I try to understand if it’s feasible on my st, I understand that there is a modification that you implement on the wiring harness, there is the details?
I'm very interested in doing this retrofit, but if you can help me a bit. ? Can you describe the process little bit, what codes did you change and in which modules? Also, what is you part # for ABS module, seller on aliexpress states that ABS module needs to be 3Q0. My car has a 5Q0, but also has ACC, so I think it should work? Thanks in advance for your help. ?
