Hi all,
Just wondering if anyone could give me some advice on some retrofitting heated seats.
I noticed the following 2 threads and it looks quite simple / interesting to do.
www.seatcupra.net
www.seatcupra.net
The car meets the requirements, and the wiring and the digital AC control unit is fairly easy to get (£100,-£200 total for these 2 components)
With a tiny exception, which is that I cannot find the heated pads for the seats, and I'd definitely want to aim for upgrading both, the pads i found are either the wrong model, or seem more expensive then a full set of new seats of Ebay for £350,-
Or does anyone happen to know where i may be able to score some of these pads at a reasonable price
Alternatively, am i best getting one of the £50,- kits of Ebay at this point if the pads are difficult to get?
Thanks,
Blue
Coding and programming - Retrofit Heated Seats - A Complete How-To
Hi guys & gals, Got a big retrofit for you all today. I've recently fitted front heated seats to my car and I must say they are brilliant! I'm very happy with the results, so I've created this guide to explain exactly how to fit this yourself...
Coding and programming - How to Remove Front Seat Upholstery & Fit Heated Pads
CHECK THE UPDATE TAB ABOVE FOR GUIDE UPDATES Hi guys & gals Today I will show you how to dismantle and remove the upholstery/covers from the front seats should you need to replace a damage part. I will also show you how to fit heated pads if you...
Thanks,
Blue
