Hi Guys, the weekend is nearly upon us, well it is for me as I work shifts
, and I would like to install my reversing sensors.
Normally this isn't an issue because locating the reversing bulb/wire is easy as it's often on the car pillar. But with the Leon it's on the boot lid cluster of lights.
Finding out which one is the reverse light isn't the problem. I will just use a multimeter, but where I am going to tap into it is.
Because the boot lid loom runs at the top
It's gonna be near impossible to tap into the wire, without damaging the roof liner or plastic clips.....
So my question is, does anyone know of a better place to tap into the reverse wire.
Even if it means running a length of wire to the front of the car under the dash.
Anyone know where this loom of wires from the boot, appear at the front....
Would the reversing bulb have its own fuse... Either under the dash or on the drivers side fuse panel... Mmmm must go and check manual...
A hint in the right direction would be greatly appreciated...
I will be doing an install guide as I do it...
Thanks in advance...
