What sort of money are you looking for dude? Do you use your lap top to enter the settings or is it all self contained?
I'd like £65 for it. It the Revo SPS Select & it has the Revo Cupra settings.
It has the following options:
Stock
Performance (Leon Cupra settings)
Anti theft on
Anti theft off
Communication
So all you'll need to do is - set it to performance & plug it in!
My warranty runs out in a couple of weeks, so won't be needing it again...... unless my I disconnect the battery!?
Stock
Anti theft on
Anti theft off
Communication
So excuse my ignorace, are all stage 1 REVO maps the same values or can i programme it to what mine should be?
Stock
Anti theft on
Anti theft off
Communication
That is the old switch, New ones have 3 performance settings which you can switch between as well as Stock and Anti-Theft Modes.
Be lucky to get £65 for it as I have just picked one of the new SPS switches up on ebay (used) for £50 delivered. Works like a dream.
If you're stage 1 - then yes... you don't want to play around with the values, as it's pointless.
It's only when you go stage 2 - you want to edit the Revo settings!
Lucky you!
Maybe I should just give it away?
Its useful for stage 1 also. to get the car setup for the temperature and altertude. Not all cars can run on the same settings sucessfully.
Also very handy to adjust timing when you run 95ron fuel.
You can not be serious..... changing it for temperature & altitude????
It all depends how anal you want to be - get a Plus to play around with the setting, which won't make much difference on stage1 motor or get a select to have it on/off.
But if you can get a Select Plus for £50..... obviously that's a better buy, but I doubt they come up that often!?
Anyway, the offers there - I'm not fussed if I keep it or not!
Ok, i'm pretty much at sea level here, so i think i'd manage. I did see the one on Ebay this week for £50, but without having a bit more info (supplied by you lot :) it was pointless me buying it.
I'll phone the REVO dealer first as i need to see if they can help out with a flat spot and if it's not viable to go all the way there, i will PM you re the sps.
Appreciate the help!
