revo problem???
Oct 12, 2005
1,013
Other the last few weeks i have noticed a decrease in pull from my car. For example in 3rd gear. Used to pull really well but no no difference. I have noticed this ever since i used a obd cable off ebay for vag com and this may have damaged the obd? I have tried switching between stock and performance and have only noticed a slight difference. Could this be to do with the hot weather even though its cold 2day. Any ideas. Has anyone else had similaru symtoms in last few weeks.
thanks
Steve_B
Stacy mmmm.......
May 6, 2005
241
West Yorkshire
The warmer weather will have some effect. Could it just be that you're getting used to the remap? I've got a remapped saab 93 and I'm already noticing after 3 weeks of driving it that it doesn't feel as quick, a look at the speedo tells me different though :D
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
Try resetting the ECU by leaving the battery disconnected for 5 mins. It might be that the ECU has got used to motorway driving etc........
Pabs
5,936
Basingstoke
yeh, think i agree with the majority here - the hotter weather certainly does hold the car back. I've thought the same every summer i've had the car.
The FMIC I have has helped, but still recon i notice a slight difference...
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
Your ECU is like a student - it constantly learns & adapts every time you drive your car (without getting drunk) !!
If you have been doing a load of motorway or granny driving of late, your ECU will adapt & be less agressive so you save on juice.
By disconnecting the battery, it will reset your ECU, giving you a more aggressive and responsive drive from the off. (Your ECU can re-adapt to a more agrressive drive, but it will take some time if you don't reset it).
This will have no adverse affects on any remaop you may have !
Oct 12, 2005
1,013
Ok guys thanks for the help. I will try reseting the ecu. However will this affect the revo. Could my car be in limp mode. There is a bit of pull however???
lukecupra2001
Smoogie And Proud
Jul 25, 2005
338
middlesbrough
do you have to disconnect the battery or can it not be done by removeing a fuse?a mate of mine has a CTR and we reset his ecu by removeing a fuse on top of the battery
Revo Kev
www.onlyrevo.com
Feb 24, 2003
1,488
www.onlyrevo.com
Disconnect the battery... reconnect, then turn on ignition and leave for a couple of minutes.
Do a fault code check
Check the peak MAF values using VAG COM
Check the load requests using VAG COM
If it's in limp mode there'll be a fault. If the MAFs reading low there won't be but the car will feel slow.
