tufftys cat had shrunk in its housing and turned 30 degrees the the axis of flow, blocking it significantly, so never say never is one of my motto's
trying to figure out hwo its holding boost, (if) its not a mutant k03s
all I am doing is running along the lines of its flow will be limited by its spec, and your airflow is not more than a k03s will move, BUT, its blowing thru something which is holding pressure upstream of the map sensor for some reason.. the analogy in my mind is its trying to blow thru a small pipe, holding up boost pressure, but not equating to flow.
achieve flow from the engines, and they make power.. Boost is just a means of shoving in said air.. If it does'nt want to flow, you can blo was hard as you like and it wont flow much more
Historically, my ibiza when ihi'd suffered a low of power/flow, and seemed to strain at higher revs where it did'nt used to..
then I looked closer to try and figure out what had changed, restricted something, and never expected to see this!!
that used to be a 2.5" bore flexi pipe before is ruptured inside and turned into a very small phincter! lol
its deffo an odd one for sure.
