CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
As above really,
What torque should the bolts be torqued up too??
Taking mines off for painting, hopefully next week when I'm off work.
Also what temperature will the rocker cover roughly reach when the engine reaches operating tempeture?? Just wondered as the Enamel paint I've got is resistant up to 120.C
Thanks all,
Craig.
hi....
when u take your cover off replace your rocker cover gasket, i thake it u have a 1.4 8v... if so the gasket pack comes with 3 rubber grommets for the 3 screws on top.
I just did them up tight, until i couldnt turn the ratchet anymore without using a bit of force. cba with all that torque stuff lol. I didn't replace the gasket as the old one wasn't cracked or broken.
hi....
Already got the rocker cover gasket. The one I got doesnt have the 3 rubber grommets for the screws on top.
EnGbudd, What did your rocker cover gasket look like?? I definetely have the right part it just looks weird.
Erm the 3 little rubbers actualy slip into the holes on the rocker cover. The gasket should be just be rectangle and the sides should arc up.
