s3 anti roll bar
Dale4Life
I lowered my Leon Cupra few month ago n it rubbed on drive shaft and stupidly without reading up I bought the adjustable drop links, this however made no difference and I've played for hours fiddling it around to see if it works, I've got it lowered and not to rub but its not low enough, I have it running on rs6 19s, question is does the Audi a3 (8l) anti roll bar fit my Cupra? Thanks people
MooRzy
245
Manchester
Yeah, i am running an S3 ARB, but i don't have adjustable drop links, so i had to fudge it a bit. but you should be okay with adjustable ones.
Dale4Life
Oh sound, does it go under or over the drive shafts, I'm running on JOM coilovers, does it fit to wish bone like the standard 1 because I read somewhere it fits to the coilover, cheers
Feb 22, 2006
517
Penzance Cornwall
The s3 anti roll bar goes under the driveshaft. But the a3 will be the same as the cupra. And you can attach the s3 to te wishbone. But needs spacers on the drop links to get them to sit straight.
MooRzy
245
Manchester
Yeah I just spaced mine out with a nut lol. Make sure you have a paitent mate to help you, takes a bit of fiddling to swap them.
Dale4Life
Ok sound n my best mate owns a bodyshop so il do it there, does the a3 arb go through the gearbox area like standard ie having to drop sub frame? Thanks a lot for the help guys appreciatte it
