__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Got my SCN stickers in the post today ive placed them in the rear 1/4`s on the car but when ive come to take the backing paper off the etched writen hasnt stuck to the window and comesback off with the backing paper, is it because the weather is cold outside and it need time to adder or should i use a hairdryer to get them stuck...
Bit of a n00b question but oh well. :)
ive just this second put mine on and had no problems. just rub the sticker until you see the out;ine clearly.
I've always used a credit card or something along those lines to push the sticker off the backing paper - then peel of the backing with the card still pushing against the window, you can then see if the sticker is sticking properly or if anything needs pushing on further.
Did you contact the vinylstore as the same happened to mine!
No i didnt i manged to get them on in one pieace in the end i found that it worked if you peel the paper back at 90deg one still messed up abit tho :(.
