Seat Ibza 6j 2.0 FR - Camshaft Position Sensor P0341 Implausible Signal
CLueless
Hi, I run into a message I don't understand while reading error code. It says Impausible signal instead of no signal. What do you think it means? I though of ordering new sensor but I don't want to go through process of returning it if in doesn't solve the issue.
The symptoms are that the car starts poorly or not at all but runs fine.
CLueless
Hi, if someone finds this thread. The sensor is malfunctioning. But sadly I didn't find a way to replace it without taking down the timing belt. Luckily after blowing on the sensor (clearing it from dust) the error disappeared. This can be a temporary solution. If someone replaced the sensor belt without replacing timing belt. Just let me know.
