I spent a long time looking online before buying and choosing a full size spare wheel for my Seat Leon mk3 ST FR. I found some quite useful information but also misleading information. I therefore thought that I would share my experiences for others considering this option.
When I bought my new Leon in November, I paid for the 18" space saver spare wheel and sub-woofer option. The sub-woofer is designed to fit inside the space saver spare wheel. I was dismayed to find how narrow the space saver spare wheel was. It was much slimmer than the one on my last car (a Skoda Octavia VRS), which was not that much slimmer than the standard wheels. The Leon space saver wheel would certainly make a big difference to the handling of the car if fitted in place of one of the normal front wheels and I certainly would not consider driving back from Eastern France using it, like I had to with the one on my previous car (as I did not speak French or have internet access and was unable to locate the correct replacement tyre). I therefore decided to replace it with a full size spare wheel.
My understanding is that the Leon mk3 and mk2 wheels share the same PCD & bolt pattern (112mm x 5) and centre bore but not the same offset. My Leon ST FR has 17" 7.5J main wheels with 225 wide tyres and the wheels have an offset of ET51. The offset may be different for other sizes of wheels fitted to the Leon mk3 but you can check what offset they have because it will be marked on the back of the wheels. As I have the sub-woofer, which will only fit into an 18" wheel, the spare wheel had to be 18". I found one on eBay for £90 inc. delivery, which was in very good condition. It was from a 2008 mk2 Leon and is an 18" 7.5J 5 spoke alloy wheel. I have fitted it with a 18" 225mm 40 ratio tyre. As the tyre has the same width and approximately the same outer circumference as those on the main wheels and the offset (and therefore the alignment) is the same, it should drive just the same as the 17" standard wheels and not be limited to low speed driving. It fits onto the hub with no problems (and does not foul anything as the wheel with tyre is effectively the same overall size as the normal wheels).
However, although it will fit into the spare wheel well/bay, it is a very tight fit. Because of the width of the wheel and tyre, it will not slide into the part of the bay which is recessed inside the bumper and therefore the hole in the centre of the wheel does not align with the position of the plastic wheel retaining mount bolt/screw (which is easily removeable) and the wheel cannot be secured inside the bay. I have not yet checked but it may fit a bit better if the tyre is deflated (I carry an electric pump). The boot floor is dual height. In the lower position, the floor will not go down fully as it rests on the wheel and is a few mm higher than it should be (I have not measured it but maybe 1/4"). As the foam insert into the bay, which holds the jack and tools for changing the wheels, is designed to fit under the space saver spare wheel, it has to be dispensed with. There is just enough room inside the full size spare wheel to put the jack and tools (which I have wrapped in bubble wrap), even with the sub-woofer in place. The sub woofer fits inside the full size wheel and works fine although how well it fits may differ with other designs of 18" wheels (and with the type I have the top of the sub-woofer is sightly higher than ideal). As my car is the ST (estate) model, I do not know what issues there would be with the hatchback models.
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
