shiftyseamus
Hmm, just bought myself a 2003 tdi 110 Leon and it seems to have 'issues'!!
When I got it I knew the central locking wasn't working and to be honest wasn't too bothered.
Not long after the car lost power so I did a scan, its come back with some scary results!!
Tuesday,21,May,2013,21:30:05:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: Mileage: 146650km/91124miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 06402
VCID: 5EB980A1DA2CB49
VSSZZZ1MZ3R121034 SEZ7Z0C1991314
2 Faults Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001 001 00001
VCID: 32610411AE34409
2 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00044
Shop #: WSC 06402
VCID: 244DF249B4C0DE9
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06441
VCID: 2241F451AED4D09
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 902 D
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05422
Shop #: WSC 00000
VCID: 2855E679C8E83A9
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to Plus - Intermittent
00667 - Ambient Temperature Signal
01176 - Key
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0E54E19B0B8B29
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06403
VCID: 3A712C312644B89
Subsystem 1 - Part No: 1C2959802A
Component: A7 Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C2959801A
Component: A7 Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: A7 Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: A7 Tõrsteuer.HR KLO 0009
9 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
End ---------------------------------------------------------------------
The Supply voltages I'm assuming are coming from the alternator fault or a bad ground/cable break/poor connection
I'm gonna mr muscle the turbo to clean the vanes.
The traction light comes on on the dash after 5 minutes(abs sensor)
The alarm goes off if you don't put the key in the ignition directly after opening the door(drivers door lock?)
Any thoughts (perhaps a gallon of petrol and an insurance claim form may help!!???)
Its done 91k miles with full history
Coding: 00002
Shop #: WSC 06402
2 Faults Found:
Readiness: N/A
Coding: 0021505
2 Faults Found:
Coding: 00044
Shop #: WSC 06402
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
Coding: 05422
Shop #: WSC 00000
3 Faults Found:
01176 - Key
Coding: 00006
Shop #: WSC 06402
Coding: 00258
Shop #: WSC 06403
9 Faults Found:
