Seat Leon tsi door locked and not opening inside or out.
Jun 20, 2021
London
Hi my door is locked and cannot open from inside or outside. It initially had a problem where the outside handle couldn't open the door when using the fob. But would work if i used the key. Now both fob and key cannot unlock the door but all others work. When i turn the key too the right its abit tight like its not going allows the way.
380bhpdaily
1,231
568
Best thing you can do is enter the car from the passenger side until you break that lock and then enter from the other doors till they stop working and then enter via the boot.
Only then when you have broken every lock on the car you can get the key fob fault fixed and you can go back to using the drivers door again.
AnotherLife
41
Best thing you can do if enter the car from the passenger side until you break that lock and then enter from the other doors till they stop working and then enter via the boot.
Ahahaha, dude, you made me burst out laughing in the middle of the night!
Reactions: 380bhpdaily
