archibald
Hi.
I have had my car serviced by my local garage and they ( and me) seem to be unable to reset the Inspection Service. The Interval service has been reset.
Problem being is the car has gone over the required mileage by 1700 ( I know that isn't good). The garage think this may be the issue.
Any ideas ?
Arch
Do you have access to VCDS or OBD11
CODING BELOW
Reset service cycles
With this mod you can reset the maintenance service notification.
1 - Module 17 - Code Box instruments- (25327)
2 - Adaptations
3 - Select - PIM: Restart prolog.interv.mant
4 - Select one of three options:
- No warning (default)
- Active Notice
- Reset
Another way:
1 - Applications
2 - Inspection service reset
3 - Select the desired
Change notice review by KM
With this mod you can reset the warning maintenance service for kilometers.
2 - Adaptation
3 - Select
4 - Fixed: Next máx.hasta mileage rev.en kil function.
5 - Change the desired value. Default 30000
6 - FIXED: resposic value. Próx.inspecc. Depending on the mileage
7 - Change to the desired value. Default 30000
8 - PIM maximum value of KM-delivery kilometric / review
9 - Change the desired value. Default 30000
10 - PIM: minimum value of km-long sandy provision / review
11 - Change the desired value. Default 15000
12 - SIA: value máx.de journey to service
13 - Change the desired value. Default 15000
Change days notice review
With this mod you can reset the maintenance service notice for days.
2 - Adaptation
3 - Select
4 - Fixed: Time má.hsta next rev. Depending on the time
5 - Change the desired value. 730 default d
6 - FIXED: reposic.próx inspecc.en value function of time
7 - Change to the desired value. Default 365 d
8 - PIM maximum value of elapsed time between overhauls
9 - Change the desired value. 730 default d
10 - PIM: minimum value of elapsed time between overhauls
11 - Change the desired value. Default 365 d
12 - SIA: value longer up service
13 - Change the desired value. Default 365 d
Reset oil change warning
With this mod you can reset the oil change notice.
1 - Applications
2 - Oil service reset
Read more: http://forum.obdeleven.com/thread/764/coding-adaptations#ixzz5N30NDJHh
and a discount for you as you had to get the answer :)
its always good to share, we all like quicker ways.
Tried that keeps coming back
My sons 15 plate TDi needs the hazards on for the reset to work.
Key in and switch on ignition.
Switch off ignition ( leave key in )
switch on hazards
push 0.0 button and keep pressed whilst switching on ignition
When reset question comes up - release 0.0 button and then press to confirm.
switch off ignition
switch off hazards
Reactions: Mr Pig
Sorry, unfortunately the document is in German.
Needs Diagnose System
  • Servicerueckstellung.pdf
