I recently had this done.....
Pads,
Disks,
Metal impellor water pump,
Cam belt,
Aux belt,
MAF sensor,
2 x Yokohama C-line tyres,
Full service,
Had radio signal booster fitted,
Had new wing mirror cover, fitted/primed/painted
MOT
£987.00 inc VAT + labour.
I was happy with the MOT, straight through, only one advisory for the tiniest of chips in the windscreen. So small I didn't even know it was there... lol
ok, i should have added, it's recently passed it's MOT, but has a 'service' warning light on. I want to spend the minimum possible for an annual service which would include oil change. I'd want change from £200.
Ok, you need then oil change, filters etc...
£200.00 ish.
Dependent on your milage/age. You may need a new Cam belt/water pump. Which is an additional £300-400 dependent on where you go.
If you do get a new cam/water pump. Get a metal impellor pump, as they are much better quality and less prone to failure (due to the impellor parts not cracking like the nylon ones do)
