james walker
cooling is the key people
May 24, 2007
5,121
retford notts
hi fellas, i have a toyosports fmic, the outlet from turbo is 2 inch and inlet to the fmic is 2.5 inch
it all fits fine and has worked fine for months, where the pipe from the hotside to the fmic reduces from the turbo outlet is a small pipe to join.
i want to lose this pipe as its joined via 2 pieces of silicon, one being 2 inch to the turbo end, and then via 2- 2.5 reducer.
so i need a reducer which is 2.5 to 2 inch but long enough to miss out the metal joiner if that makes sense??
ive seen plenty of reducers but all seem to be not long enough.
ideally 6inchs long, but can get away with 5, most i see are 4 inches which wont be long enough
anyone know where i can get one, or any other ideas??
thanks in advance
james, try custom chrome racing, they have a website and could also make you one upto your desired length as they do custom exhausts.
cooler works ok like this, but ive got it in my head its a restriction so that joining pipes got to go tbh.
i routed mine so it was a strait path with no bend like yours, with the outlet for n75 and dv pointing left near the turbo. like the oem position.
Has been bugging me a bit too, for the same reason and it's actually annoying having to remove the joiners all the time to gain access to that area (which I had to do for the TIP), if it was one long pipe (like adam cupra's) it would be perfect or, as you are considering playing with the idea of a reduced long hose.
Wouldn't it need to be at a bend though?
try this lot they will make you a custom one for whatever length you want for not alot of money I got a few for a custom FMIC setup from them..
performancesiliconehoses.com
