Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
On 50% of gear changes i get a slight engine overrun. I know its not related to the switch on the clutch pedal as i've had that go before and thats much worse. When the cars cold it dosnt overrun at all and shifting feels very positive, but once warmed up the gear changes seem sloppy. It almost feels like im pressing the clutch pedal really slowly when shifting. Its done it ever since ive had the car but i know its not right and its bugging me now.
So far i've tried a different DV and also a different N75 and tried driving in various different ways to eliminate it, but cant seem to cure it. Any ideas?
My car does exactly the same. Has done for ages. I'm told its a throttle body leak? But i've checked all pipework and can't find nothing. So i've put up with it.
I've tried 3 different clutch pedal switches, all of which i've taken apart and cleaned the contacts with a pencil rubber. And i've aligned my throttle body plenty of times since i've had the car, so i don't know what it could be.
Do we have a throttle position switch? Maybe thats not cutting fuel fast enough enough when lifting off to shift gear.
Glad i've found someone else with the problem (unlucky for you though), as sometimes i start thinking i'm imagining it.
Just to add, the faster/harder i'm driving, the worse it is. Is it worth me popping the hose off the throttle body and seeing if its sealing properly?
youll need to do a sweep test on throttle potentiometer and is the clearance correct on clutch switch????
How do i do that then, vag com? Also, how can i find out the correct clearance for the switch, as i had to make a custom bracket to hold that switch as the stock one was rubbish.
This problam is quite common mate. I did a search on here a while back, and its been covered quite a bit.
The threads that i read about, 9/10 the over revving was solved by checking/replacing the clutch pedal sensor as most peoples plastic holder clip had broke. But this is not the case with my car.
Do a search on 'holding revs' or 'continued revving during gear cange'.
I'm sure thats what i searched.
Let me know if you do solve it, please!
I made a metal bracket and fastened the switch to it with a jubilee clip and also tried 3 different switches so i don't think the switch is at fault this time.
I still have no clue mate, i tried a clutch switch that i know works and mounted it in the correct position as i measured in a mates Ibiza. But that had no effect. Infact, my car drives just the same with it unplugged completely :shrug:
So i guess i can rule that out as having anything to do with it. Other than that, no clue :(
So annoying ent it.
My engine management light sometimes comes on, im sure its related to the over revving thing.
I've tried plugging Vag-Com in, but it don't interface with my car...another isuse!!
So annoying ent it.
Yeah its crap really, mines very intermittent too. Mine has never thrown a light though. I'm tempted to take mine somewhere to get it looked at but sometimes its so minor that i'm not sure anyone else will notice it.
I'm now thinking maybe its throttle body related, ie not closing quick enough when letting off throttle? Could the throttle body plenum have become stiff maybe? Or maybe the motor powering it is slower than it should be?
