Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Roach do you have any resistors left? Xanax can the red/black cable just be cut?
I got some 10a off eBay and it's working fine, the slow speed is only something like 7.5a I think.Sorry didnt reply roach been on nights. But got some now anyway. Quick question about cable anyone. Cant find 10a cable, seen 11a on a quick search. Is this suitable considering the high speed fan runs at 15a. To me I should need higher than 15a?
Can I add why do you think the water pump is faulty surely the high speeds was working before hand as you say and not after if the water pump was faulty it would want to overheat causing high speed fans to be on more surely....my low speeds was not working at all not even with air con and my high speeds seems to be pulsate and rather loudly aswell the new fans have now cured my problem... I can get the high speed fans on just by leaving it ticking over for around 30 minutes my liquid gauge shows around 94oc once the fans comes on...
Sent from my iPad using Tapatalk HD
The high speed fan only comes on at 106c according to my liquid gauge, and since I've fixed the slow speed fan I've never had the coolant temp once go into triple figures so far, that includes some hard driving with the recent hot weather we've been having, as long as the needle doesn't go past 90 I wouldn't worry about it tbh.
Exactly the same buddy.Does the OP fix work for normal LC's? I notice its been done on a LCR for the purpose of this thread. My slow speed fans dont work and am looking to sort it out via whats been said in this thread providing the wiring is the same.
