Spark Plugs - Upgrade
dmpx
101
50
My Cupra 280ST is getting a major service in the next few weeks and one thing getting replaced is the spark plugs.
The car is currently running about 370bhp with a number of mods, and alongside Millers Nanodrive NT+ 5w40 I would like to use upgraded spark plugs.
Does anyone know what ones are actually an improvement? I’ve seen posts about RS6/7 plugs etc but not sure exact what is required...
Any help would be massively appreciated.
paddy6789
1,627
1,082
Preston, Lancs
There’s two ways of going really - the OEM RS7 plugs (around £70-80 for a set) or the NGK race plugs (around £120 for a set).
I personally went for RS7 plugs on my 2016 290 and now my R. Partly because of the cost but also because if they’re good enough for a stock RS7, they’re good enough for my Cupra :)
Sent from my iPhone using Tapatalk Pro
Reactions: dmpx
dmpx
101
50
Brilliant - Thank you for your help! I’ll get a set of RS7s ordered.
Where did you get yours? I can only seem to find them in packs of 8 for the RS7s V8
paddy6789
1,627
1,082
Preston, Lancs
I ordered mine from TPS when you used to be able to walk in. You could always try RPS or a local VAG specialist. 06K905601M is the part number, just ask for 4 :)
Reactions: dmpx
dmpx
101
50
As always, you’ve been a great help! Thanks
paddy6789
1,627
1,082
Preston, Lancs
The RS3 coil pack part number is 06H905110L :)
I’m running the same as Damo - RS3 coil packs with RS7 spark plugs.
Reactions: dmpx
ray
590
191
I thought about this for my next service which is due soon, currently stock but will be looking into a map within the coming months.
What are the actual advantages to running these plugs? Any improvement in power/torque or anything noticeable or all placebo as mentioned above?
Thanks,
paddy6789
1,627
1,082
Preston, Lancs
Thanks,
I think it’s more of a reliability and strength upgrade than a noticeable power/torque upgrade. But I did feel the car ran smoother after changing them out.
Stefan147
193
140
Athens Greece
Previous gen EA888 used to work much better with upgraded plugs/coils when mapped. I don't know if that's the case with gen3 as well but if I got a map I would upgrade them.
