Hi guys,
I recently replaced the rear discs and pads on my FR TDI and at the same time, I took the front brakes off so that I could apply some copper grease to the pads to stop the insanely loud screeching when I pressed the brake.
At first, all was well, the brakes made no noise at all and they worked perfectly. However after a few days (a week at the most) they have started to make a squeak again, in all fairness the squeak is no where near as loud as before and it only occurs when a decent amount of pressure is applied to the brakes, whereas before you only had to look at the brakes the wrong way and they would start squeaking!
I have taken the pads out again and regreased everything in an attempt to solve it but it seems to have made very little, if any effect at all.
The issue seems to be the front brakes, the rear makes no noise at all.
Can someone point me in the right direction as to what to do please?
I am considering taking it to a garage, I dont really want to do this as it would take away from the fact that I fitted the rears fine by myself.
Thanks for looking guys!
