Stage 2 cupra
Jun 24, 2007
967
durham
In the process of swapping my tdi fr for a cupra , when searching I'm getting completely head fcuked with what mods are actually needed to get a stage two map that I'm hoping to go to straight away . So from a bog standard cupra what mods and at what price is everything I'm looking at? Will go with Apr for the map as I've used them before and seem highly rated still . Also will clutch need replacing or is that stage 2+ issue
jreedy
turbo'd ep3- Fr tdi leon
May 13, 2008
369
sheffield
I've just bought a cupra mate and I'm in the process of gathering bits ready for stage 2 power
As far as I'm aware all that's needed for stage 2-
Uprated intake such as revo/ITG/Neuspeed
3" turbo back (de-cat or a sports cat system)
Cooler is optional as the mk2 Cupra one is good enough for 375 (sure I read that)
Then obviously a good map/software such as revo/APR/GLAC
Stage 2 power is anywhere from 330-350
Stage 2 + is the above with a high pressure fuel pump and again cooler is optional
Again mapping/software to suit
Stage 2+ power can be as high as 385 bhp
I think that's about right mate..... I'm sure others will tell me otherwise if there's any bits that are wrong.
olitaylor07
Badger Badger
Jul 15, 2012
2,422
West Yorkshire
Clutch can go after stage one just depend on the condition.
Usually air intake, REVO. Ect.
Turbo back exhaust but I'm sure a down pipe with sports car or decat will be fine. And there you go
Jun 24, 2007
967
durham
So I'm looking at 411 for downpipe and decat , 230 intake and 500 for a map and I'm good to go with a few quid saved back I case the clutch starts to go ?
Joshkcupra
Local Retard
Aug 21, 2012
899
Gravesend, Kent
Well if the clutch goes you're looking at around £1200 to replace the lot, and if you replace it you might aswell go single mass, to stop it from chewing through another clutch in no time.
Feb 6, 2014
1,323
Lincoln
I wouldn't expect the clutch to last long at stage 2, I think they are rated to 300lbft. Add a bit of wear to it and I would say that you can almost guarantee it will slip. Might as well play it safe and uprate it from the off.
jreedy
May 13, 2008
369
sheffield
I've just paid 6k for a 57 plate Leon cupra (full s/h 67k) bought private... Got the seller down from £6500
It's cost me upto now
£181 (eibach sportlines)
£234 (Neuspeed P-Flow intake)
Booked in at exhaust uk next week for 3" turbo back £700
Next I'll get booked in at statller for a GLAC map. That a probably about £500
So with the above it's cost me just shy of £1500 (power mods) to go stage 2.... And that's buying new parts.... Cheaper if you get 2nd hand bargains
967
durham
Are you just waiting to see how you get on with clutch then replacing when needed ?
jreedy
May 13, 2008
369
sheffield
I'm going to go ahead and go for a stage 2 map
I'll replace the clutch if and when it starts to slip
Cupra james
72
Ive been told on mine all is needed now is
4Bar fuel pressure regulator
I have the exhaust system, sports cat, air filter, forge 007p and stage one revo.
Now ready for stage 2
Cupra james
72
Sounds mega dear!!! glad mine was done before i bought it!!!
Joshkcupra
Local Retard
Aug 21, 2012
899
Gravesend, Kent
Id definitely recommend upgrading the air intake to something larger like a Revo/Evoms/ or MTC otherwise you won't be making full potential of the car at stage 2 with a PFlo
jreedy
May 13, 2008
369
sheffield
I was going to buy the evoms intake to start with, I decided for the price of that I may as well buy the Neuspeed P-Flow as well as eibach springs for the same price.
The MTC kit is also a nice bit of kit, I can't see why it's any different to the P-Flow I have...... The bore size of the P-flow isn't any different..... In fact the P-flow is a nice mandrel bent piece of piping with a filter on the end..... Same as the ITG also.... The ITG is 3" which is slightly bigger
The turbo inlet is the same size no matter what cold air Intakes fitted
