hixonseatboy
286
Alright guys.
For the last few weeks been having a odd issue. My car just won't start it gets to turn over just nothing leaving it a while seems to do the trick.
Today tho it still would not start and felt stupid sitting on the car park trying. But after I give it a few press on the throttle it come to life.
The problem seems to go away once its happend and then comes back again and goes away. Seems a strange one.
Any idea's? When it work starts first time with ease.
Mine done this, try and get Vagcom on it when it won't start, was only way I found the fault, it was the crank postion sensor,
does it prime the fuel pump when it won't start?
Sent from my HTC Wildfire S using Tapatalk 2
Can't hear the pump but mite not be lising hard enought.
Don't have vagcom got a cheap eBay scanner but was showing no codes when would not start.
I was getting no signal intermitant but the code would clear when it worked. Doubt it'll pick it up, if the crank position sensor is not sending a signal, then the pump won't prime. You really need Vagcom.
The crank pos sens is about 100quid, and must be a genuine one, pattern parts dont fit properly and wont let the car rev.
So you could inspect the sensor but I've a broken one I took out that looks perfect so it won't help much. Could of course be other things..... But sounds identical to my fault
