steering problem
flash
144
Leeds
i know there have been messages about this before but i still have a problem
basically, when going over bumps i have a knocking feeling through the steering wheel
a few months ago my local dealer (reluctantly) changed a clamp that is on the steering collumn down behind the pedals (behind a plastic cover). That helped but it is starting to rattle again
the dealer is useless and i thought i would ask if anyone else has had a similar problem?? - it makes the car nasty to drive
:cheers:
CupRacer
I had this twice on my Ibiza before I sold it earlier this year.
My problem was the bearing at the top of the column just behind the steering wheel.
Dealer refused to acknowledge the problem until I forced them to remove the steering wheel and check. After removing the bearing there was 1-2mm of movement in the inner bearing race!!!
The bearing was changed and it cured the problem.
muddyboots
Still hanging around
Oct 16, 2002
5,739
I had exactly the same problem on my Rover 220SDi, the column bearing was worn and allowed the column to rattle during turns over bumpy ground.
