I guys recently carried out a MFSW upgrade project
Had to change the steering wheel control module to accommodate the MFSW
Originally I had the 1K0 953 549 BC and went for a 1K0 953 549 CH
Everything before the change worked fine
Since I have fitted the new module I have an issue with the cruise control
the errors I have are found on this link
https://www.dropbox.com/sc/5kp4nwzok9h79zz/1a206TagwC
my setup for the module is 0000134
https://www.dropbox.com/sc/jbcpog51suns6bz/jJlauJcWjh
based on this info
https://www.dropbox.com/sc/wqz1e3ngrnpoj4j/sx83HY7gxT
My cruise control is on the same stalk as the indicators
The main on / off switch works okay but the set key doesn't seem to work
I had to change the workshop number and equipment number to 12345 and the importer number to 123, somebody said this could be the reason for the fault code
Any help would be GGGGGGRRRReat
Thanks for reading
Dai O
based on this info
Thanks for reading
Dai O
