steering wheel - facelift to preface
ferooo
Hi,
is there any way to change steering wheel on preface Leon Cupra with facelift steering wheel?
What about airbag plug connector and steering wheel controls? Will that fit and work?
thanks ;)
Benzy
1,214
I saw a pfl fitted with a fl steering wheel on auto trader so it can b done, however I don't no how to do it mate sorry
Sent from my HTC Wildfire using Tapatalk
ahadmehmood
32
Hi,
thanks ;)
hi do you know anyone that has done this mod as I have a leon withn steering upgrade however none of the controls work
p11lkw
325
:I do believe its possible. Facelift steering wheel with facelift steering control module is what you need. Then it will probably need coding and you should be good to go. I've opted for pre facelift instead as by time I'd found out it was possible I'd already ordered a new steering wheel :cry:
Apr 5, 2011
787
Somerset
Guys Ive bought a new wheel and cant wait to fit it, Here is a photo of the old one now
this is the one I am fitting
I would love to know if anyone has done this is so what was done what had to be done for aribad ans steering wheel controls
p11lkw
325
You will need a Steering control module from a facelift car to enable the steering controls to function. Not too sure about the airbag think that should be ok from what I've heard. Let us no how you get on with the install along with pictures please
p11lkw
325
Ross tech will give you part numbers for the control module which is located under the steering column. Replacing the steering wheel wont take long, Have you got all the tools ?
Apr 5, 2011
787
Somerset
I have the tool yes I just need an airbag and the module, Wish someone would show me a link on someone else doing it before me though haha
p11lkw
325
New steering wheel all fitted/ coded and working. Only took around 10 mins to do.
p11lkw
325
Needed VCDS to code the steering controls. Mainly the gear shifts as mine already had radio/phone buttons.
Apr 6, 2010
543
Any luck with this? Does anyone know the part number for the facelift steering control module?
